Enables RIPng to redistribute routes from other routing functions.
direct | Specifies interface routes (only interfaces that have IP forwarding enabled are exported). |
ospfv3 | Specifies all OSPFv3 routes. |
ospfv3-extern1 | Specifies OSPFv3 external route type 1. |
ospfv3-extern2 | Specifies OSPFv3 external route type 2. |
ospfv3-inter | Specifies OSPFv3-inter area routes. |
ospfv3-intra | Specifies OSPFv3-intra area routes. |
static | Specifies static routes. |
isis | Specifies IS-IS routes. |
isis-level-1 | Specifies IS-IS Level 1 routes. |
isis-level-1-external | Specifies IS-IS Level 1 External routes. |
isis-level-2 | Specifies IS-IS Level 2 routes. |
isis-level-2-external | Specifies IS-IS Level 2 External routes. |
bgp | Specifies BGP IPv6 routes |
e-bgp | Specifies EBGP routes. |
i-bgp | Specifies IBGP routes. |
cost number | Specifies the cost metric, from 0-15. If set to 0, RIPng uses the route metric obtained from the route origin. |
tag number | Specifies a tag number. |
policy-name | Specifies a policy. |
Disabled. However, direct routes will always be advertised for all the interfaces where RIPng is enabled. For those interfaces where RIPng is not enabled, the corresponding direct route could be redistributed if direct route export is enabled through this command.
Default tag is 0.
This command enables the exporting of static, direct, IS-IS, and OSPFv3-learned routes from the routing table into the RIPng domain. You can choose which types of IS-IS or OSPFv3 routes are injected, or you can simply choose isis or ospfv3, which will inject all learned routes (of all types) for the selected protocol.
The cost metric is inserted for all RIPng-learned, static, and direct routes injected into RIPng. If the cost metric is set to 0, the cost is inserted from the route table. The tag value is used only by special routing applications. Use 0 if you do not have specific requirements for using a tag.
Each protocol can have a policy associated with it to control or modify the exported routes. The following is sample policy file which modifies the cost of redistributed routes from OSPFv3 and statically configured routes:
entry filter_rt { If match any { Route-origin ospfv3; Route-origin static; } then { cost 10; } }
The following command enables RIPng to redistribute routes from all OSPFv3 routes:
enable ripng export ospfv3 cost 0
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
